Polyscope X Error installing urcapx on physical robot and simulator
Hello everyone,
I am developing an URCAP for the new Polyscope X. For some time now, I have been implementing the backend in Python and the frontend in Angular. I was able to simulate it correctly during development, but recently I tried to install it on a physical robot and when I restarted it, it wouldn’t go past the loading screen.
Then I tried again in the simulator and got the same error as on the physical robot. It had been working for months during development. I tried previous versions and different commits that did work, but now they don’t.
Any idea what might be happening? Could it be a library that has been updated from the backend, the version of Docker Desktop, or a problem compiling the urcapx file?
I also looked at the logs in the containers and via SSH on the physical robot, but I didn’t see anything relevant.
At this moment where it remains loading.
Thank you all in advance.
I was able to solve the problem.
Apparently, if you have too many ports open in your work environment, Visual Code in mine, it can cause problems when installing urcapx in the simulator.
By closing all of them except 4200, I was able to install it correctly.
