Where are the logs in Polyscope X?
Where can I see logs in Polyscope X, e.g.
textmsg("Hello, World!")
It is stated in the URScript manual for PolyScope X:
The PolyScope log-tab is intended for general application status.
However, I couldn’t find this tab.
I continue peeling the onion.
all of them are empty
# ls -la /tmp/log/urcontrol/interpreter.*
-rw-r--r-- 1 root root 55 Feb 24 16:33 /tmp/log/urcontrol/interpreter.0.log
-rw-r--r-- 1 root root  0 Feb 24 16:33 /tmp/log/urcontrol/interpreter.log
-rw-r--r-- 1 root root 55 Feb 24 16:33 /tmp/log/urcontrol/interpreter.saved.log
# ps aux | grep urcontrol
root        1475 39.7  2.5 422624 421932 ?       SLsl 15:09  45:50 /ur/bin/urcontrol/URControl  -m 10.11.0 -n /UR20256803177
root        1523  0.0  0.0 172000 13240 ?        S    15:09   0:00 journalctl -fu urcontrol
Here is also nothing interesting
# journalctl -fu urcontrol
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:92374 01:56:40:374 INFO    - Starting program: aia_example_apriltags6adb
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:92382 01:56:40:374 INFO    - Runtime state change: from PROGRAM_STATE_STOPPED to PROGRAM_STATE_RUNNING
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:93200 01:56:40:378 INFO    - XMLRPCClient - connecting to: servicegateway:80
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:93207 01:56:40:378 INFO    - XMLRPCClient - creating http transport
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:94019 01:56:40:392 INFO    - XMLRPCClient - connecting to: servicegateway:80
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:94026 01:56:40:392 INFO    - XMLRPCClient - creating http transport
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:95661 01:56:40:410 INFO    - Opening library: /ur/bin/rostypes/humble/libur_ark_ros_common_msgs__rosidl_typesupport_c.so
Feb 24 17:06:09 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:09:96482 01:56:40:411 INFO    - Opening library: /ur/bin/rostypes/humble/libur_ark_ros_common_msgs__rosidl_typesupport_introspection_c.so
Feb 24 17:06:17 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:17:47385 01:56:47:922 INFO    - Runtime state change: from PROGRAM_STATE_RUNNING to PROGRAM_STATE_STOPPING
Feb 24 17:06:17 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:17:47404 01:56:47:924 INFO    - Runtime state change: from PROGRAM_STATE_STOPPING to PROGRAM_STATE_STOPPED
Feb 24 17:06:17 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:17:47406 01:56:47:926 INFO    - Socket "XMLRPCClientSocket" object was destroyed.
Feb 24 17:06:17 ur-20256803177 urcontrol.sh[1475]: 2026-02-24_17:06:17:47407 01:56:47:926 INFO    - Socket "XMLRPCClientSocket" object was destroyed.
Hello @andrei.kholodnyi
the log messages can be found under Application > System Info > Log Messages.
This is being described in the correspondent part of the PolyScope X SW Manual
See the following screen shot as reference:
This message will then be part of the log_history.txt file in case you export the overall logfiles.
Let me know in case you need further insights!
Thank you, found it!
Is it a way to retrieve logs remotely without storing them to the log_history.txt file via GUI.
The currently available flight reports can be found under /ur/var/flightreports und the controller.
There are always the 5 latest ones stored.
Thank you @sko, I just got my UR20 back from Embedded World, and will give it a try
@sko well, it is not obvious where should I look for the program’s logs?
I have
 python3 -m zipfile -l /ur/var/flightreports/recording_20256803177_20260317_16_42_35.zip
File Name                                             Modified             Size
files/.allow-empty                             2026-03-17 15:42:34            0
files/Xorg.0.log                               2026-03-17 15:42:34        28402
files/aia_example_apriltags.json               2026-03-17 15:42:36       141583
files/aia_example_apriltags.script             2026-03-17 15:42:36        61263
files/bootstrapper.log                         2026-03-17 15:42:34            0
files/df                                       2026-03-17 15:42:36         2899
files/docker_ps.log                            2026-03-17 15:42:36         2646
files/frontend-app.log                         2026-03-17 15:42:36       196032
files/global_variables.csv                     2026-03-17 15:42:34          694
files/interpreter/interpreter.0.log            2026-03-17 15:42:34           55
files/interpreter/interpreter.log              2026-03-17 15:42:34            0
files/interpreter/interpreter.saved.log        2026-03-17 15:42:34           55
files/kern.log                                 2026-03-17 15:42:36        79947
files/log_history.txt                          2026-03-17 15:42:34      1268193
files/memory_usage_of_system.log               2026-03-17 15:42:34          207
files/ps                                       2026-03-17 15:42:34        26137
files/realtimedata.csv                         2026-03-17 15:42:48     58889616
files/robot_metrics/joint1.bin                 2026-03-17 15:42:34         1564
files/robot_metrics/joint2.bin                 2026-03-17 15:42:34         1564
files/robot_metrics/joint3.bin                 2026-03-17 15:42:34         1564
files/robot_metrics/joint4.bin                 2026-03-17 15:42:34         1564
files/robot_metrics/joint5.bin                 2026-03-17 15:42:34         1564
files/robot_metrics/joint6.bin                 2026-03-17 15:42:34         1564
files/robotiq_robotiq_drivergripper.log        2026-03-17 15:42:40     16234253
files/robotiq_robotiq_robotiqbff.log           2026-03-17 15:42:36         3823
files/ros2-web-bridge.log                      2026-03-17 15:42:36         2145
files/system.environment                       2026-03-17 15:42:34          394
files/universal-robots_aia-core_calib_studio-backend.log 2026-03-17 15:42:36          936
files/universal-robots_ros-message-compiler_ros-message-compiler.log 2026-03-17 15:42:36            0
files/universal-robots_sw-licensing-psx_sw-licensing-psx-backend.log 2026-03-17 15:42:36            0
files/universal-robots_urcap-system-api_urcap-system-api.log 2026-03-17 15:42:36            0
files/universal-robots_urconnect-main_urconnect.log 2026-03-17 15:42:36        57838
files/universal-robots_urconnect_urconnect-telemetry.log 2026-03-17 15:42:36            0
files/universal-robots_web-frontend-app_web-recording-engine.log 2026-03-17 15:42:36            0
files/ur-auth.log                              2026-03-17 15:42:34            0
files/urcontrol/.last_seen_joint_positions.conf 2026-03-17 15:42:34          282
files/urcontrol/URControl.log                  2026-03-17 15:42:34        35596
files/urcontrol/calibration.conf               2026-03-17 15:42:34         1043
files/urcontrol/controller_timestamp.dat       2026-03-17 15:42:34          113
files/urcontrol/firmware_appinfo.yaml          2026-03-17 15:42:34         8078
files/urcontrol/ftsensor.conf                  2026-03-17 15:42:34         1170
files/urcontrol/joint_info.txt                 2026-03-17 15:42:34         1062
files/urcontrol/joint_motor_calibration_id0.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_motor_calibration_id1.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_motor_calibration_id2.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_motor_calibration_id3.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_motor_calibration_id4.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_motor_calibration_id5.txt 2026-03-17 15:42:34          429
files/urcontrol/joint_null.conf                2026-03-17 15:42:34          443
files/urcontrol/joint_size0_eseries.conf       2026-03-17 15:42:34          389
files/urcontrol/joint_size1_eseries.conf       2026-03-17 15:42:34          406
files/urcontrol/joint_size2_5_gen6.conf        2026-03-17 15:42:34          398
files/urcontrol/joint_size2_eseries.conf       2026-03-17 15:42:34          404
files/urcontrol/joint_size3_eseries.conf       2026-03-17 15:42:34          416
files/urcontrol/joint_size4_eseries.conf       2026-03-17 15:42:34          423
files/urcontrol/joint_size4_gen6.conf          2026-03-17 15:42:34          398
files/urcontrol/joint_size5_gen6.conf          2026-03-17 15:42:34          395
files/urcontrol/metadata.n3                    2026-03-17 15:42:34          616
files/urcontrol/robot_calibration_summary.txt  2026-03-17 15:42:34         5070
files/urcontrol/ros-id                         2026-03-17 15:42:34           14
files/urcontrol/safety.conf                    2026-03-17 15:42:34         4079
files/urcontrol/server.conf                    2026-03-17 15:42:34           52
files/urcontrol/ur-robotarm-serial             2026-03-17 15:42:34           96
files/urcontrol/ur-serial                      2026-03-17 15:42:34           12
files/urcontrol/urcontrol.conf                 2026-03-17 15:42:34         1922
files/urcontrol/urcontrol.conf.UR10            2026-03-17 15:42:34         1898
files/urcontrol/urcontrol.conf.UR10_DC         2026-03-17 15:42:34         1900
files/urcontrol/urcontrol.conf.UR16            2026-03-17 15:42:34         1895
files/urcontrol/urcontrol.conf.UR16_DC         2026-03-17 15:42:34         1897
files/urcontrol/urcontrol.conf.UR20            2026-03-17 15:42:34         1922
files/urcontrol/urcontrol.conf.UR20_DC         2026-03-17 15:42:34         1924
files/urcontrol/urcontrol.conf.UR3             2026-03-17 15:42:34         1615
files/urcontrol/urcontrol.conf.UR30            2026-03-17 15:42:34         1866
files/urcontrol/urcontrol.conf.UR30_DC         2026-03-17 15:42:34         1868
files/urcontrol/urcontrol.conf.UR3_DC          2026-03-17 15:42:34         1618
files/urcontrol/urcontrol.conf.UR5             2026-03-17 15:42:34         1645
files/urcontrol/urcontrol.conf.UR5_DC          2026-03-17 15:42:34         1647
files/urcontrol/urcontrol_env.conf             2026-03-17 15:42:34           18
files/urdeployd.log                            2026-03-17 15:42:34            0
files/urservice.log                            2026-03-17 15:42:36         1578
metadata.json                                  2026-03-17 15:42:48        10530
summary.log                                    2026-03-17 15:42:48         9895
