Sending script command via primary interface
Is there any way to check whether the script command send via primary interface is successfully completed or not?.
Hi Jerry,
Do you want to know if the script has reached its end? If so, you can check via Dashboard whether the program is running or not with the command running. It will tell you whether is there a program/script running or not.
Unless the script is well written, it will not run. At least, that is my experience
Best regards,
Pedro Monforte
