Hello! It looks like my URCap broke URSim a little, but I can’t figure out what the problem is. Nothing happens when you try to start the program. Maybe someone has encountered something like this?
13:38:13.530 ERROR - Failed to load installation: /home/ur/ursim/ursim-5.8.0.10253/programs/default.installation {thread: Thread-3 , loggerClass: gui.installation.services.RobotInstallationLookupServiceImpl}
13:38:13.532 ERROR - Failed to load installation, creating ‘default.installation’ {thread: Thread-3 , loggerClass: gui.installation.services.SingleRobotInstallationSite}
13:38:13.611 WARN - Not connected to controller, trying to send string:
stop program
{thread: Thread-3 , loggerClass: com.ur.polyscope.controllerinterface.internal.ControllerSocket}
13:38:13.622 WARN - Not connected to controller, trying to send string:
stop program
13:38:13.625 WARN - Not connected to controller, trying to send string:
stop program
13:38:13.634 WARN - Not connected to controller, trying to send string:
stop program
13:38:13.681 WARN - Method used before correct value has been received from controller, returning default = joint_max_speed {thread: Thread-3 , loggerClass: com.ur.polyscope.robot.configuration.joint.JointConfigurationSettings}
13:38:13.681 WARN - Ignoring any future reports of error {thread: Thread-3 , loggerClass: com.ur.polyscope.robot.configuration.joint.JointConfigurationSettings}
13:38:13.766 WARN - Not connected to controller, trying to send string:
stop program
13:38:13.834 WARN - Not connected to controller, trying to send string:
stop program
Jul 04, 2021 1:38:14 PM com.steadystate.css.parser.CSSOMParser
WARNING: java.lang.ClassNotFoundException: com.steadystate.css.parser.SACParserCSS21 not found by org.w3c.css.sac [160]
WARNING: using the default ‘SACParserCSS21’ instead
Upgrading Conveyor Tracking as G5 due to IO changes
13:38:15.959 WARN - Not connected to controller, trying to send string:
stop program
13:38:15.960 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.050 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.071 WARN - Not connected to controller, trying to send string:
sec load_installation():
set_tool_communication(False, 115200, 0, 1, 1.5, 3.5)
set_tool_output_mode(0)
set_tool_digital_output_mode(0, 1)
set_tool_digital_output_mode(1, 1)
set_tool_voltage(0)
step_count_72cae218_eb7f_4d66_a257_0681edf36326 = 0
thread Step_Counter_Thread_a840695d_3c9a_4251_b54c_51dac337e22a():
while (True):
step_count_72cae218_eb7f_4d66_a257_0681edf36326 = step_count_72cae218_eb7f_4d66_a257_0681edf36326 + 1
sync()
run Step_Counter_Thread_a840695d_3c9a_4251_b54c_51dac337e22a()
set_safety_mode_transition_hardness(1)
set_tcp(p[0.0,0.0,0.0,0.0,0.0,0.0])
set_payload(0.0)
set_gravity([0.0, 0.0, 9.82])
set_standard_analog_input_domain(0, 1)
set_standard_analog_input_domain(1, 1)
set_tool_analog_input_domain(0, 1)
set_tool_analog_input_domain(1, 1)
set_analog_outputdomain(0, 0)
set_analog_outputdomain(1, 0)
set_input_actions_to_default()
13:38:16.171 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.180 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.191 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.204 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.208 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.408 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.422 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.481 WARN - Not connected to controller, trying to send string:
stop program
13:38:16.621 WARN - Not connected to controller, trying to send string:
set_tool_voltage(0)
while (True):
sync()
set_payload(0.0)
13:38:23.807 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosBaseNormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:23.814 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosShoulderNormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:23.814 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosElbowNormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:23.817 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosWrist1NormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:23.818 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosWrist2NormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:23.819 WARN - No parent window for message: Value cannot be greater than given maximum value. (component: minPosWrist3NormalMode.JointsLimitsPanel) {thread: Thread-3 , loggerClass: com.ur.swing.DisplayMessageFactory}
13:38:24.048 WARN - Not connected to controller, trying to send string:
stop program
13:38:24.049 WARN - Not connected to controller, trying to send string:
stop program
13:38:29.362 ERROR - RobotState messages are queued up: 3 {thread: RobotState - PostMan , loggerClass: com.ur.monitor.RobotState$PostMan}
