I have this code line where i want to add a scriptNode with a script to set a boolean true. But I can’t find the scriptNode in the addchild() command. So is there a way to go around this?
As you can se now I’m just using commentNode with a text to make the (user) add the scriptNode by himself and put in the right script.
Thanks in advance!
Best regards Martin
