Hi Developers,
I need from my URCap to insert some defined scripts files in the Treenodes, but there is no scriptNode in the ProgramNode interface.
Is there a work around that?
Best Jens
Hi Developers,
Best Jens
Create a program node, and insert this as a placeholder.
Insert this at the relevant places.
Use the URCap Proprietary API to define the script it should add in its ScriptWriter.
You could optionally add a meaningful title and description in the node using the same API to tell the user what this node is doing.
Could you give a example on it?
Best Jens
Yes, in this example:
