Create script line
Is there a way to create a script line from an URCap?
Udklip
(I don’t need the script to set a digital out, it is just used as an example)
I can make it create comments and moves, but not scripts.
You can not add script node form urcap.
Possibly you can go around it by adding variable assignment node?
Or create a URCap program node, where you from the parent node, can define the URScript it contributes.
The problem I hoped to get around with this, is related to this Create waypoint with variable - #3 by michael.andresen, where I had hoped I could make a more simple program tree. Every time the robot comes to the urcap, it needs to go to a different position than last time. I already got the pose it needs to go to in a variable, I just can’t figure out how to make it use that variable.
My current solution got the script doing everything, but I want it to be more flexible and easier to add and modify.
