How to Add a tab in I/O Tab
@jbm
I need add a Tab named “Kingtic” in I/O Tab. Is there any way to implement it?
It is not possible, to create a new tab in the IO section using the current API.
However it is possible to do so from an installation node, alternatively second some of the feature request in the Feature Request category regarding e.g. Toolbars if run screen access is desired.
OK, I see. Thank you very much!
