The Purpose of the urscript xml rpc calls is to use the functionality on robot program runtime. If you don‘t need it on runtime you should implement the xml rpc client on the java layer. I think this is covered in the Xml rpc math example
Related topics
| Topic | Replies | Views | Activity | |
| URCap Sample: XML-RPC Math URCap | 8 | 4040 | July 3, 2020 | |
| Concepts of installation, program node and remote server | 1 | 681 | April 22, 2020 | |
| Calling an URCap from Tree Robot Instructions (Polyscope or URsim) | 1 | 525 | October 1, 2020 | |
| URCap Sample: URCap with XML-RPC Server by Java (Dialog Script URCap) | 1 | 2831 | May 5, 2023 | |
| Call a java function in the URCap from a custom URScript file | 2 | 760 | September 11, 2021 |
