Hi All,
How to change the IP in URsim ?.
I want to connect the AB PLC to URSim.
Thanks in advance.
Hi All,
Thanks in advance.
You have to edit file /etc/network/interfaces to set up a fix IP in the same subnet as your PLC. Then, set up Virtual Box to use Host-Only Ethernet Adapter
Follow this tutorial : Get started with .NET - UnderAutomation
Then, I suppose your AB PLC is connected to your PC physical adapter. So you’ll have to set up a Bridge between your physical ethernet adapter and your Virtualbox Host-Only Ethernet Adapter : How to Setup Bridge Connections on Windows 10
