Ethernet/IP don't work anymore on URSim 5.15
Steps to reproduce:
Run ./install.sh URSim 5.15 and then ./start-ursim.sh UR20, enable Ethernet/IP in installation tab.
Expected Behavior:
Working E/IP on URSIM
Actual Behavior:
PLC is not able to connect to the URSim since 5.15 version
Workaround Suggestion:
Use 5.14 or older URSim. It works even on the same VM.
Robot Serial Number:
URSIM
Affected Version(s):
5.15.1
