Hello all,
I’m working with a robot that has (2) grippers upon the same robot end, both have URCaps. Recently a colleague shared with me that if the power goes out in our factory, the (second) gripper upon startup reassigns itself to gripper ID #1, thereby conflating itself with the original (first) gripper, both being assigned ID #1, instead of reassigning itself back to gripper ID #2.
Is there a way to fix this problem? Potentially a “script” that would assign a peculiar gripper to a particular ID in the “before start” of the program tree? Right now we just have a popup prior to start that tells the operator to double check the ID of the grippers upon starting.
Any ideas would be helpful, thank you.
