Is there a way to figure if the robot is inside or outside of an area?
My idea would have been to define a feature plane that defines the limit of the area.
Next I would like to convert the current position of the TCP into the feature plane so that I can determine if z> 0 then the TCP is within the limit, if z <0, then the TCP is out of limit.
How can I calculate the current TCP position in the feature plane like under the tab “Move” in URScript?
Thank you.
