Hi all,
I want to connect a UR10e to TOYOPUC PLC(PC10G-CPU) with EtherNet/IP.
just setup Link parameter (which port in the CPU use) and connection setting (UR IP address) and enabled EtherNet/IP function in the robot.
However the robot can not communicate with scanner. yellow indicator iluminatted.
the PLC looks no EDS required.
could someone please give me advice for this connection?
thank you
Hiro
