Hi, i have a welding urcap, where is not possible to edit the TCP parameters manually in Polyscope, is setted in urcap java code.
If i change the welding torch, i need to setup new TCP parameters. Where, and how can i modify the urcap java code for making enable the TCP parameter editing?
