Hi UR team. We have seen a change in the behaviour when copying a Wapoint in SW3.11.0.
In versions before, when you copy a Waypoint, it creates an independent copy, i.e., is not linked to the original Waypoint. So you can modify the copy or the original without affecting the other.
In version 3.11.0, when you copy a Wapoint, by default it creates a copy linked to the original Waypoint. So if you modify the copy or the original, it affects the other. Our technical crew thinks this can lead to errors.
Is this a bug or a new feature?
Could you consider leaving it as it was before?
Thank you for your great work and support!!
SW3.11.0, CB3.1, UR10, Spanish.
