Change Polyscope Language in Docker Container
Hello UR-Team,
I have a question regarding the Docker Image you provide for the eseries robots (Polyscope 5). I would like to change the language of Polyscope, ideally by mounting the right drectory such that the file, in which the language setting is stored, is kept persistent. Currently, I have also mounted the programs-directory and the urcaps-directory to be able to test new versions of our urcap as fast as possible.
Can you tell me, where the respective file is stored or a different way that you would suggest to change the language as easy as possible?
Best,
Dion
