Hi.
We have an UR10, have this process where we set screws through a palletizing process. At each movement the screwdriver is activated and the screw is set before moving to the next. Simple.
The issue is that we use an irregular pattern and every time the station is set, I have to calibrate all 16 holes (2 sets of 8).
I would like to use pose_trans to determine all positions to the first one, but I can’t figure out how to do it.
I have tried doing it inside the pattern, before the pattern, as a thread and even before the program starts.
Is there a way to set the pattern points outside the pattern?
Thank you very much.
