Is it feasible? I want the locations data and I want to command the robot go to those locations by PLC.
you try to just add offsets to a base position.
MoveJ Waypoint 1 **{starting point}**
var_1:get_actual_tcp_pose() **{Assignment}**
loop 8 times
loop 5 times **{ Loops As needed }**
MoveJ Var_1
Var_1[1]=var_1[1]+.02 **{ Script element: [1] Y Offset, .02 meters}**
var_1[0]=var_1[0]+.05 **{ [0] X offset, .05meters}**
var_1[1]=var_1[1]-(.02*5) **{Remove Y offset * loop}**
