HI All,
I am a UR user in Hong Kong and find the UR panel show this message to me.
“XZ - compressed data is corrupt. System halted”
I have no ideas for this case and even it is not a error code.
Have any one can share your experience with me. Thank you very much.
Hi Tim,
this looks like a problem with Linux. It is probably due to bad memory (DRAM), or bad settings in BIOS. Changing the memory load settings to the default helped in other cases.
Did you change any settings yourself? When did this error occur? ![]()
Greetings,
Jakub
Hi Tim,
we experienced the same with the UR10e controller. Using a new SD card with a fresh image was the solution in our case.
Best,
Witalij
