Use Reduced Mode as a variable
I am trying to figure out if I can set or change a variable when the co-bot is in reduced mode? Or control an output when the robot is in reduced mode? Thanks for the help.
You can read this value from the Fieldbus interface (like through a PLC) or via the Dashboard server.
You can set up a configurable output to mirror reduced mode. It should be low when reduced mode is inactive and high when active. :slight_smile:
