The container runs fine and I can connect to it via VNC-Viewer on localhost:5900.
However, I do get the “No Controller” Error and can not do anything with the simulator. Did you run into this? If so how did you fix it?
It does appear that there is a general incompatibility of the URControl binary with arm64 systems even with virtualization. There is always some sort of error no matter what I try.
