I have an unsupported UR5 CB2 system that has developed an error when running. The error is: C55A52: Safety system error. I am using version 1.6, which has been removed from support. I have tried shutting down and restarting, but after it comes up, the error reappears. Has anyone experienced or heard of this issue that could help by giving me your insight? I am thinking that it is a Universal Robots JM766A Masterboard error/fault but am unsure. I have looked at the manual and it only states that the error is a “C55A52 5V - 3V3 or ADC error - 5V too low”. I am willing to buy a replacement board (new or used) if that is the reason for the fault. I would like to stay with version 1.6 so that I don’t have to try to upgrade the software on the system. Any insights would be greatly appreciated. Thanks in advance. Rick Russell
I have the same problem. I did replace the masterboard and that did not solve the issue. When I look at the logs, I see a message about Wrist 2. Could wrist 2 be causing the 5v loss? Are there any test points or terminals to check that?
Did you replace the masterboard or the safety board? If wrist 2 was drawing too much power (due to load or failure) it could cause the 5v to drop and trigger the safety board I suppose and cause the shutdown. I don’t know about any test points to check. I suppose you could compare 2 wrist joints to see if there is a difference to point you in a direction. Where do I view the log files? I get an error message popup, but if there are logs that might be more detailed, that might help lead me to the proper solution. Where did you find/purchase parts? Mine is a version 1.6 that is handwritten on the safety board. I have found a used version 1.8 board on Ebay, but the only software upgrade available on the software download is for 1.8. I read that you need to upgrade to version 1.7 and then 1.8 to get to version 1.8. Any help or insight you can provide would be very helpful. Thanks!
- Masterboard and Safety Control Board are the same.
In CB2 there’s a motherboard and a masterboard (called Safety Control Board in CB3, yes). - You can retrieve the log file with a magic file found on UR’s download site. It’s a good idea to check it for underlying issues related to the other fualt.
- CB2 parts are no longer available from UR, so you have to be lucky to find a distributor, who has some in stock. I would definitely advise you to consider how much money you want to spend on the robot due to this exact reason - if it breaks again in the future, it will be even harder to fix it.
- You can find legacy software updates here: Universal Robots - LEGACY DOWNLOAD CENTER
It’s correct that you need to update to 1.7 and then 1.8.
If you upload the log file here after you retrieve it, I will take a look at it, too. But, to me, it sounds like it’s a faulty masterboard (SCB). I have replaced a masterboard due to this exact error (C55A52) before, which solved the issue.
Yes, in CB2, Masterboard is Safety Board. That is the board I replaced. I did purchase this on Ebay, and it is 1.8. My board was 1.7, so I did not have to upgrade to 1.7, just 1.8.
The same seller on ebay has the MS-9856 board, however; I have read nothing leading me to believe that this board is related to the issue.
When I boot up, and try to initialize, these are the messages I get on the log tab.
C101A0: Real Robot Connected
C100A3: Robot changed mode: Initializing
C184A4: Joint self test not completed: Wrist 2
C100A4: Robot Changed Mode: SECURITY STOPPED
Wrist 2 C55A52: Safety System Error: 5V, 3v3 or ADC error (5V too low).
I believe that since the Masterboard did not fix the issue, and Wrist 2 comes up, it may be causing the issue. Still troubleshooting.
So how do I retrieve the log file? If I knew where to find it I could make a copy to my USB drive. I see the utility to use to view it that you load on a windows pc.
If I buy a masterboard that is version 1.8, do I have to upgrade the software to 1.8 or is it backwards compatible? Would the 1.6 software still function?
If I can retrieve the log file, I will upload it so you can take a look.
I really appreciate your expertise!
As I said already, you need a magic file to retrieve the log file. The magic file can be found on UR’s download page. ![]()
“Magic file” doesn’t say much, I guess, but it’s a file you put on a USB drive from your PC and then insert the USB in the UR Teach Pendant or controller, and it will then retrieve the log file and store it on the USB.
Magic file: https://www.universal-robots.com/download/software-e-series/support/magic-files/magic-file-backup-log-history-file/
Leave the USB in the robot for 30 minutes or so. It’ll take a while for these old robots.
There are two models of the masterboard. If you’re getting a newer model, you might have to update as far as I remember. Though, if it’s coming from a robot, it’s most likely the old model. So you won’t have to update. ![]()
Yeah. Haven’t seen that before, sadly.
******** Log start (2023-06-30 10:01:42) ********
T 0023d20h08m49.056s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
V 0023d21h45m39.200s URControl URControl 1.8.11281 (Aug 07 2013)
T 0023d21h45m39.200s PolyScope Connected to Controller
R 0023d21h45m16.632s URControl C101A0: Real Robot Connected
R 0023d21h45m16.640s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h45m16.648s URControl C116A189: Realtime part warning
R 0023d21h45m16.656s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d21h45m16.656s TeachPendant1 C31A4: Caught wrong message (not from master)
R 0023d21h45m16.656s TeachPendant2 C31A4: Caught wrong message (not from master)
R 0023d21h45m16.656s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d21h45m23.480s SafetySys C72A1: Starting UR5
R 0023d21h45m23.496s SafetySys2 C72A1: Starting UR5
R 0023d21h45m23.680s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d21h45m23.736s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d21h45m39.152s RTMachine Cannot drive robot, program stopped
R 0023d21h45m48.792s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h47m56.832s URControl C100A0: Robot changed mode: OK
T 0023d21h49m19.488s RTMachine Program sim_automatic_move started
T 0023d21h49m20.376s RTMachine Program sim_automatic_move started
T 0023d21h49m22.512s RTMachine Program automatic_move started
T 0023d21h49m26.776s RTMachine Program sim_automatic_move started
T 0023d21h49m27.360s RTMachine Program automatic_move started
T 0023d21h51m24.080s RTMachine Program side1 started
R 0023d21h51m32.256s TeachPendant1 C55A52: Safety system error: 5V, 3V3 or ADC error (5V too low)
R 0023d21h51m32.264s SafetySys C55A131: Safety system error: Safety system error
R 0023d21h51m32.320s Wrist 2 C48A224: Powerbus voltage drop detected.
R 0023d21h51m32.320s Wrist 3 C48A224: Powerbus voltage drop detected.
S 0023d21h51m32.328s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d21h51m32.328s Base C48A224: Powerbus voltage drop detected.
R 0023d21h51m32.328s Shoulder C48A224: Powerbus voltage drop detected.
R 0023d21h51m32.328s Elbow C48A224: Powerbus voltage drop detected.
R 0023d21h51m32.328s Wrist 1 C48A224: Powerbus voltage drop detected.
R 0023d21h51m32.328s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d21h51m32.400s Wrist 3 C4A0: Broken communication error
R 0023d21h51m32.400s Tool C4A0: Broken communication error
R 0023d21h51m32.408s Base C4A0: Broken communication error
R 0023d21h51m32.408s Shoulder C4A0: Broken communication error
R 0023d21h51m32.408s Elbow C4A0: Broken communication error
R 0023d21h51m32.408s Wrist 1 C4A0: Broken communication error
R 0023d21h51m32.408s Wrist 2 C4A0: Broken communication error
R 0023d21h51m32.416s URControl C107A5: Joint has too many errors in a row
R 0023d21h51m32.416s URControl C105A5: Joint not responding: Wrist 3
R 0023d21h51m32.416s URControl C107A6: Joint has too many errors in a row
R 0023d21h51m32.416s URControl C105A6: Joint not responding: Tool
R 0023d21h51m32.424s URControl C107A0: Joint has too many errors in a row
R 0023d21h51m32.424s URControl C105A0: Joint not responding: Base
R 0023d21h51m32.424s URControl C107A1: Joint has too many errors in a row
R 0023d21h51m32.424s URControl C105A1: Joint not responding: Shoulder
R 0023d21h51m32.424s URControl C107A2: Joint has too many errors in a row
R 0023d21h51m32.424s URControl C105A2: Joint not responding: Elbow
R 0023d21h51m32.424s URControl C107A3: Joint has too many errors in a row
R 0023d21h51m32.424s URControl C105A3: Joint not responding: Wrist 1
R 0023d21h51m32.424s URControl C107A4: Joint has too many errors in a row
R 0023d21h51m32.424s URControl C105A4: Joint not responding: Wrist 2
T 0023d21h51m32.432s RTMachine Program side1 stopped
T 0023d21h52m10.440s RTMachine Program side1 stopped
T 0023d21h53m06.352s RTMachine Program side1 started
T 0023d21h53m44.152s RTMachine Power button pressed
T 0023d21h53m47.184s RTMachine Power button pressed
******** Log end (2023-06-30 10:13:31) ********
******** Log start (2023-06-30 10:14:46) ********
T 0023d21h41m45.584s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
T 0023d21h53m49.536s PolyScope Connected to Controller
V 0023d21h53m49.536s URControl URControl 1.8.11281 (Aug 07 2013)
R 0023d21h53m26.664s URControl C101A0: Real Robot Connected
R 0023d21h53m26.672s URControl C116A104: Realtime part warning
R 0023d21h53m26.672s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h53m26.680s URControl C116A191: Realtime part warning
R 0023d21h53m26.688s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d21h53m26.688s TeachPendant1 C31A4: Caught wrong message (not from master)
R 0023d21h53m26.688s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d21h53m33.528s SafetySys C72A1: Starting UR5
R 0023d21h53m33.544s SafetySys2 C72A1: Starting UR5
R 0023d21h53m33.728s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d21h53m33.784s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d21h53m49.496s RTMachine Cannot drive robot, program stopped
R 0023d21h53m51.880s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h54m07.832s URControl C100A0: Robot changed mode: OK
T 0023d21h54m46.224s RTMachine Program sim_automatic_move started
T 0023d21h54m46.232s RTMachine Program automatic_move started
T 0023d21h54m50.408s RTMachine Program sim_automatic_move started
T 0023d21h54m57.408s RTMachine Program automatic_move started
T 0023d21h55m34.432s RTMachine Program side1 stopped
T 0023d21h56m21.056s RTMachine Program side1 stopped
T 0023d21h56m21.128s RTMachine Program side1 stopped
T 0023d21h56m24.312s RTMachine Program side1 started
T 0023d21h56m50.112s RTMachine Program side2 stopped
T 0023d21h56m55.160s RTMachine Program side2 stopped
T 0023d21h56m55.216s RTMachine Program side2 stopped
T 0023d21h57m01.776s RTMachine Program side2 started
T 0023d21h57m36.784s RTMachine Program side3 stopped
******** Log end (2023-06-30 10:19:02) ********
******** Log start (2023-08-15 15:02:37) ********
T 0023d21h53m09.952s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
T 0023d21h57m42.448s PolyScope Connected to Controller
V 0023d21h57m42.448s URControl URControl 1.8.11281 (Aug 07 2013)
R 0023d21h57m19.576s URControl C101A0: Real Robot Connected
R 0023d21h57m19.584s URControl C116A213: Realtime part warning
R 0023d21h57m19.584s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h57m19.592s URControl C116A191: Realtime part warning
R 0023d21h57m19.600s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d21h57m19.600s TeachPendant1 C31A4: Caught wrong message (not from master)
R 0023d21h57m19.600s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d21h57m26.448s SafetySys C72A1: Starting UR5
R 0023d21h57m26.464s SafetySys2 C72A1: Starting UR5
R 0023d21h57m26.648s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d21h57m26.704s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d21h57m42.424s RTMachine Cannot drive robot, program stopped
R 0023d21h57m49.128s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d21h59m09.528s URControl C100A0: Robot changed mode: OK
R 0023d21h59m51.312s TeachPendant1 C55A52: Safety system error: 5V, 3V3 or ADC error (5V too low)
R 0023d21h59m51.320s SafetySys C55A131: Safety system error: Safety system error
S 0023d21h59m51.392s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d21h59m51.384s Base C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.384s Shoulder C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.384s Elbow C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.384s Wrist 1 C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.384s Wrist 2 C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.384s Wrist 3 C48A224: Powerbus voltage drop detected.
R 0023d21h59m51.392s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d21h59m51.464s Base C4A0: Broken communication error
R 0023d21h59m51.464s Shoulder C4A0: Broken communication error
R 0023d21h59m51.464s Elbow C4A0: Broken communication error
R 0023d21h59m51.464s Wrist 1 C4A0: Broken communication error
R 0023d21h59m51.464s Wrist 2 C4A0: Broken communication error
R 0023d21h59m51.464s Wrist 3 C4A0: Broken communication error
R 0023d21h59m51.464s Tool C4A0: Broken communication error
R 0023d21h59m51.480s URControl C107A0: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A0: Joint not responding: Base
R 0023d21h59m51.480s URControl C107A1: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A1: Joint not responding: Shoulder
R 0023d21h59m51.480s URControl C107A2: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A2: Joint not responding: Elbow
R 0023d21h59m51.480s URControl C107A3: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A3: Joint not responding: Wrist 1
R 0023d21h59m51.480s URControl C107A4: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A4: Joint not responding: Wrist 2
R 0023d21h59m51.480s URControl C107A5: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A5: Joint not responding: Wrist 3
R 0023d21h59m51.480s URControl C107A6: Joint has too many errors in a row
R 0023d21h59m51.480s URControl C105A6: Joint not responding: Tool
T 0023d22h01m57.760s RTMachine Power button pressed
******** Log end (2023-08-15 15:09:07) ********
******** Log start (2023-08-15 15:12:38) ********
T 0023d21h55m14.848s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
T 0023d22h02m00.848s PolyScope Connected to Controller
V 0023d22h02m00.848s URControl URControl 1.8.11281 (Aug 07 2013)
R 0023d22h01m37.984s URControl C101A0: Real Robot Connected
R 0023d22h01m37.992s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h01m38.000s URControl C116A189: Realtime part warning
R 0023d22h01m38.008s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d22h01m38.008s TeachPendant1 C31A4: Caught wrong message (not from master)
R 0023d22h01m38.008s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d22h01m44.856s SafetySys C72A1: Starting UR5
R 0023d22h01m44.864s SafetySys2 C72A1: Starting UR5
R 0023d22h01m45.056s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d22h01m45.104s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d22h02m02.648s RTMachine Cannot drive robot, program stopped
R 0023d22h02m05.136s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h03m11.768s URControl C100A0: Robot changed mode: OK
T 0023d22h03m43.576s RTMachine Program sim_automatic_move started
T 0023d22h03m45.968s RTMachine Program automatic_move started
R 0023d22h24m16.600s TeachPendant1 C55A52: Safety system error: 5V, 3V3 or ADC error (5V too low)
R 0023d22h24m16.608s SafetySys C55A131: Safety system error: Safety system error
S 0023d22h24m16.680s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h24m16.672s Base C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.672s Shoulder C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.672s Elbow C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.672s Wrist 1 C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.672s Wrist 2 C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.672s Wrist 3 C48A224: Powerbus voltage drop detected.
R 0023d22h24m16.680s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h24m16.752s Base C4A0: Broken communication error
R 0023d22h24m16.752s Shoulder C4A0: Broken communication error
R 0023d22h24m16.752s Elbow C4A0: Broken communication error
R 0023d22h24m16.752s Wrist 1 C4A0: Broken communication error
R 0023d22h24m16.752s Wrist 2 C4A0: Broken communication error
R 0023d22h24m16.752s Wrist 3 C4A0: Broken communication error
R 0023d22h24m16.752s Tool C4A0: Broken communication error
R 0023d22h24m16.768s URControl C107A0: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A0: Joint not responding: Base
R 0023d22h24m16.768s URControl C107A1: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A1: Joint not responding: Shoulder
R 0023d22h24m16.768s URControl C107A2: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A2: Joint not responding: Elbow
R 0023d22h24m16.768s URControl C107A3: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A3: Joint not responding: Wrist 1
R 0023d22h24m16.768s URControl C107A4: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A4: Joint not responding: Wrist 2
R 0023d22h24m16.768s URControl C107A5: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A5: Joint not responding: Wrist 3
R 0023d22h24m16.768s URControl C107A6: Joint has too many errors in a row
R 0023d22h24m16.768s URControl C105A6: Joint not responding: Tool
T 0023d22h24m16.712s RTMachine Program side2 stopped
T 0023d22h24m22.040s RTMachine Program side2 stopped
T 0023d22h24m26.936s RTMachine Power button pressed
******** Log end (2023-08-15 15:35:34) ********
******** Log start (2023-08-15 17:01:06) ********
T 0023d22h01m20.568s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
V 0023d22h24m28.712s URControl URControl 1.8.11281 (Aug 07 2013)
T 0023d22h24m28.712s PolyScope Connected to Controller
R 0023d22h24m06.040s URControl C101A0: Real Robot Connected
R 0023d22h24m06.048s URControl C116A139: Realtime part warning
R 0023d22h24m06.048s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h24m06.056s URControl C116A194: Realtime part warning
R 0023d22h24m06.064s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d22h24m06.064s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d22h24m12.904s SafetySys C72A1: Starting UR5
R 0023d22h24m12.912s SafetySys2 C72A1: Starting UR5
R 0023d22h24m13.104s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d22h24m13.152s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d22h24m28.680s RTMachine Cannot drive robot, program stopped
R 0023d22h24m40.104s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h27m03.728s URControl C100A0: Robot changed mode: OK
R 0023d22h27m22.960s TeachPendant1 C55A52: Safety system error: 5V, 3V3 or ADC error (5V too low)
R 0023d22h27m22.968s SafetySys C55A131: Safety system error: Safety system error
S 0023d22h27m23.040s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h27m23.032s Base C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.032s Shoulder C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.032s Elbow C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.032s Wrist 1 C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.032s Wrist 2 C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.032s Wrist 3 C48A224: Powerbus voltage drop detected.
R 0023d22h27m23.040s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h27m23.104s Tool C4A0: Broken communication error
R 0023d22h27m23.112s Base C4A0: Broken communication error
R 0023d22h27m23.112s Shoulder C4A0: Broken communication error
R 0023d22h27m23.112s Elbow C4A0: Broken communication error
R 0023d22h27m23.112s Wrist 1 C4A0: Broken communication error
R 0023d22h27m23.112s Wrist 2 C4A0: Broken communication error
R 0023d22h27m23.112s Wrist 3 C4A0: Broken communication error
R 0023d22h27m23.120s URControl C107A6: Joint has too many errors in a row
R 0023d22h27m23.120s URControl C105A6: Joint not responding: Tool
R 0023d22h27m23.128s URControl C107A0: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A0: Joint not responding: Base
R 0023d22h27m23.128s URControl C107A1: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A1: Joint not responding: Shoulder
R 0023d22h27m23.128s URControl C107A2: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A2: Joint not responding: Elbow
R 0023d22h27m23.128s URControl C107A3: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A3: Joint not responding: Wrist 1
R 0023d22h27m23.128s URControl C107A4: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A4: Joint not responding: Wrist 2
R 0023d22h27m23.128s URControl C107A5: Joint has too many errors in a row
R 0023d22h27m23.128s URControl C105A5: Joint not responding: Wrist 3
T 0023d22h28m32.680s RTMachine Power button pressed
******** Log end (2023-08-15 17:05:30) ********
******** Log start (2023-08-15 17:06:38) ********
T 0023d22h23m54.728s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
T 0023d22h28m35.576s PolyScope Connected to Controller
V 0023d22h28m35.576s URControl URControl 1.8.11281 (Aug 07 2013)
R 0023d22h28m12.704s URControl C101A0: Real Robot Connected
R 0023d22h28m12.712s URControl C116A208: Realtime part warning
R 0023d22h28m12.712s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h28m12.720s URControl C116A192: Realtime part warning
R 0023d22h28m12.728s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d22h28m12.728s TeachPendant1 C31A4: Caught wrong message (not from master)
R 0023d22h28m12.728s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d22h28m19.576s SafetySys C72A1: Starting UR5
R 0023d22h28m19.584s SafetySys2 C72A1: Starting UR5
R 0023d22h28m19.776s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d22h28m19.824s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d22h28m40.912s RTMachine Cannot drive robot, program stopped
R 0023d22h28m43.680s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h29m45.528s URControl C100A0: Robot changed mode: OK
T 0023d22h31m19.896s RTMachine Program sim_automatic_move started
T 0023d22h31m23.480s RTMachine Program sim_automatic_move started
T 0023d22h31m26.584s RTMachine Program automatic_move started
T 0023d22h32m07.248s RTMachine Program side2 started
T 0023d22h32m41.664s RTMachine Program side2 stopped
T 0023d22h32m47.920s RTMachine Program side2 stopped
T 0023d22h33m14.064s RTMachine Program side2 started
T 0023d22h33m59.424s RTMachine Program side1 started
R 0023d22h34m33.104s TeachPendant1 C55A52: Safety system error: 5V, 3V3 or ADC error (5V too low)
R 0023d22h34m33.112s SafetySys C55A131: Safety system error: Safety system error
S 0023d22h34m33.176s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h34m33.168s Wrist 2 C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.168s Wrist 3 C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.176s Base C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.176s Shoulder C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.176s Elbow C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.176s Wrist 1 C48A224: Powerbus voltage drop detected.
R 0023d22h34m33.176s URControl C100A9: Robot changed mode: ROBOT SHUTDOWN
R 0023d22h34m33.248s SafetySys C44A6: CRC error, likely from joint
R 0023d22h34m33.248s Tool C4A0: Broken communication error
R 0023d22h34m33.256s Base C4A0: Broken communication error
R 0023d22h34m33.256s Shoulder C4A0: Broken communication error
R 0023d22h34m33.256s Elbow C4A0: Broken communication error
R 0023d22h34m33.256s Wrist 1 C4A0: Broken communication error
R 0023d22h34m33.256s Wrist 2 C4A0: Broken communication error
R 0023d22h34m33.256s Wrist 3 C4A0: Broken communication error
R 0023d22h34m33.264s URControl C107A6: Joint has too many errors in a row
R 0023d22h34m33.264s URControl C105A6: Joint not responding: Tool
R 0023d22h34m33.272s URControl C107A0: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A0: Joint not responding: Base
R 0023d22h34m33.272s URControl C107A1: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A1: Joint not responding: Shoulder
R 0023d22h34m33.272s URControl C107A2: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A2: Joint not responding: Elbow
R 0023d22h34m33.272s URControl C107A3: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A3: Joint not responding: Wrist 1
R 0023d22h34m33.272s URControl C107A4: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A4: Joint not responding: Wrist 2
R 0023d22h34m33.272s URControl C107A5: Joint has too many errors in a row
R 0023d22h34m33.272s URControl C105A5: Joint not responding: Wrist 3
T 0023d22h34m33.200s RTMachine Program sim_automatic_move stopped
T 0023d22h34m48.112s RTMachine Program sim_automatic_move stopped
T 0023d22h35m04.240s RTMachine Power button pressed
******** Log end (2023-08-15 17:13:57) ********
******** Log start (2023-09-07 16:40:55) ********
T 0023d22h27m32.272s PolyScope PolyScope 1.8.11281 (Aug 07 2013)
T 0023d22h35m06.952s PolyScope Connected to Controller
V 0023d22h35m06.952s URControl URControl 1.8.11281 (Aug 07 2013)
R 0023d22h34m43.784s URControl C101A0: Real Robot Connected
R 0023d22h34m43.792s URControl C100A3: Robot changed mode: INITIALIZING
R 0023d22h34m43.800s URControl C116A200: Realtime part warning
R 0023d22h34m43.808s SafetySys2 C50A16: Robot powerup failure: Warning, waiting for Screen (Check cable)
R 0023d22h34m43.808s SafetySys C69A0: End of startup messages from Masterboard to Controller
R 0023d22h34m50.624s SafetySys C72A1: Starting UR5
R 0023d22h34m50.640s SafetySys2 C72A1: Starting UR5
R 0023d22h34m50.824s URControl C100A5: Robot changed mode: EMERGENCY STOPPED
R 0023d22h34m50.880s URControl C100A7: Robot changed mode: ROBOT POWER OFF
T 0023d22h35m06.936s RTMachine Cannot drive robot, program stopped
I’m honestly not sure what it means, when it says a component in front.
But yours could look like a fault in the Teach Pendant.
I don’t see the “a component in front” in the logs I posted. Are you looking at my uploaded text?
So do you think replacing the masterboard will resolve my issue?
I honestly don’t know. It sounds more like the same issue sales1 has observed.
It’s a fifty-fifty between the masterboard and teach pendant in my eyes.
Did you ever come to a resolution for this problem?
