UR - Siemens PLC communication problem
I have a problem with connection between Siemens PLC 1215C and UR3 E-series.
I was following the instructions on this official website and when I went online, error appeared saying:
“No diagnostics data available because the current online configuration differs from the offline configuration data.”
I’m wondering if there’s more GSD files I can try or what else can I do to solve this problem.
Thank you!
Your error is difficult to isolate from the information you’re giving. :slight_smile:
Have you assigned the device name to the UR in TIA Portal?
Correct IP address in PLC, robot and hardware configuration?
It says the online and offline configurations don’t match: Have you uploaded the hardware configuration to the PLC?
Are you using a switch between robot and PLC? There have been multiple cases of the switch being the issue. Try another one.
Looks like I haven’t uploaded hardware changes. Now it works. Thank you so much for help!
Hello again, when l tried to run the program next time, it didn’t work. I got some new errors about protection level I think. Here’s some more screenshots. Thanks you.
That protection warning is not related to PROFINET and the UR. :slight_smile:
Try assigning device name again and restart everything.
