Checking to see if someone has seen this before and what my issue might be? I’ve already switched out the pendant, and have the same problem. When I power up the robot, I get the Universal Robot label on the screen. It then pops up DVI no signal in the bottom left of the screen. After a few seconds the bottom left changes to Scanning ports, no signal. Then the screen goes completely black.
Any thoughts on this would be helpful. Is it a communication cable, main board issue??
Please reach out to your distributor and create a service case in myUR.
https://myur.universal-robots.com/
If you don’t have a myUR account yet, you’ll need to sign up and wait for account activation. Your distributor can create a case on your behalf to speed up the process.
I have this same issue. Did you ever find a resolution?
