Socket Communication in generateScript()
I am trying to get the values of get_actual_tcp_pose() and modbus_get_signal_status in Java.
So I am trying to push these 2 variables to the Sockets like this:
            String RETURN_IP = "127.0.0.1";
            int RETURN_PORT = 30003;
            String RETURN_SOCKETNAME = "\"EXPORT_SOCKET\"";
            writer.appendLine("socket_open(\""+RETURN_IP+"\","+RETURN_PORT+","+RETURN_SOCKETNAME+")");
            writer.appendLine("global float_val = get_actual_tcp_pose()");
            writer.appendLine("socket_send_string("+"float_val"+","+RETURN_SOCKETNAME+")");
            writer.appendLine("socket_close("+RETURN_SOCKETNAME+")");
But when I try to read them like this:
            Socket returnSocket = new Socket("127.0.0.1", 30003);
            BufferedReader read1 = new BufferedReader(new InputStreamReader(returnSocket.getInputStream()));
            input1 = read1.readLine();
            read1.close();
            returnSocket.close();
It says java.net.ConnectException: Connection refused (Connection refused)
On the line: Socket returnSocket = new Socket(“127.0.0.1”, 30003);
Can not we get variables from URScript when the program is running?
Thank you,
MB
This could be helpful for your case:
