Is there any document available to setup RTDE via ethernet/IP. with a PLC controller.
We have a beckhoff controller with which we want to establish RTDE communication with UR10e robot.
RTDE and ethernet/IP are overlapping options. Both produce almost the same data. RTDE is commonly used to interact with the robot from a PC using C++ or Python.
If you already have the Beckhoff, I would just use e/ip.
see here: Ethernet IP guide - 18712 - collaborative robots support
Is there a particular point that you are struggling with?
