Hi
I’m trying to control a magnetic tool changer that is attached to the UR10e with the ROS Driver. To release the tool from the tool changer, a voltage of 24V needs to be applied to the tool I/O of the UR10e. I found the parameter use_tool_communication where the tool voltage can be set, however, this voltage cannot be changed during runtime.
So my question is, how can I set the voltage of the Tool I/O pins of the UR10e via the Universal_Robots_ROS_Driver package at runtime?
