Continuing the discussion from Problem with Sensopart UR Cap:
Hello, I"m running into the same difficulty with the “Set Parameter Failed” error. Is there troubleshooting I could try to get past this last step?
Any feedback would be appreciated.
Thank you,
Matt
If you do not get a response here, you should contact Sensopart instead. Klaus, who responded to the old thread, is from Sensopart.
