Hello @jelu
What kind of setup are you using - Starterpackage / DevelopmentContainer / Native etc. ?
Does this happen for all samples?
Did you made any adjustments to the samples you try to install?
/Stefan
Hi Stefan
I am not sure the difference of the three setups you mean. But my SI downloaded the latest SDK from here. I assume it should be a Starterpackage
Universal Robots - URCaps SDK -
This happens for all samples.
No adjustment was made. Just follow the instruction.
Just FYI., my SI uses a X64 PC with Ubuntu 20.04
What environment are you using to compile the samples? Most folks will generally download eiother the full VM implementation which contains a pre-setup installation of eclipse and the SDK, or the dockerised version of the SDK package, developing through VSCode.
That being said, have you run the ./install.sh on your machine inside the SDK folder on your machine?
Sam
If this is the first time you are setting up, perhaps this youtube tutorial will help:
(Beginners URCap Tutorial – Part 1 / Set up your dev environment - by uniquelymade)
