Script Exporter
I was looking to use the ScriptExporter as provided in this post ScriptCommunicator. I wanted to test retrieving Pose data from a pose_trans calculation as a string but I seem to always receive a null value back. Is there something I am missing for properly retrieving the data using the exporter?
ScriptExporter export = new ScriptExporter();
		ScriptCommand commandString = new ScriptCommand("scriptExport");
		commandString.appendLine("new_pose = pose_trans(some_pose1,some_pose2)");
		commandString.appendLine("return_value = to_str(new_pose )");
		String resultString = export.exportStringFromURScript(commandString, "return_value");
		System.out.println("String result is: "+resultString);
I also tried skipping the return_value and just using the Pose variable as the return value as well with the same results.
Hi @anon32693620,
Have you tried with the class ScriptProxy ?
Ebbe
