I have an existing UR5/CB3 in operation on machine A. I need to set up a UR5e on machine B with similar function/job. What is the efficient way to program the UR5e on machine B? Is it as straightforward as porting over the current UR5/CB3 program on machine A to machine B? Kindly advise on the different methods that I can use.
Welcome to the forum!
You should be able to copy the program from the original robot to the new robot. Once you copy the program over you can make any changes to it that you need to make it work in the new cell.
