SafeGuard Reset buttons in parallel
Hi everyone,
I was wondering, if you can connect three physical buttons (dual channels - two switches per button) in parallel (because they are NO) and connect them only to two Configurable inputs? The same way as you would do with Safeguard safety inputs in series (because they are NC).
This is to save some configurable inputs for other periphery.
Thanks!
As it’s Reset push buttons.
Having 3 or more NO contact in parallel is perfectly fine!
