I have noticed it is possible to run a secondary program via port 30001 also when the robot arm is powered OFF.
Is this officially supported and can be used in URCaps as a standard solution to do things e.g. control IO channels, or is it just an ‘issue’ that should not be used and will be removed from future versions?
Csaba
