Hello, I have been trying to connect to UR5 with ur_rtde library and I constantly receive the following error:
RuntimeError: One of the RTDE input registers are already in use! Currently, you must disable the EtherNet/IP adapter, PROFINET or any MODBUS unit configured on the robot. This might change in the future
I have disabled Ethernet, Modbus and Profinet. I also checked existing connections using the following command: netstat --all --program | grep 30004
and there was none. I also checked all Ethernet, Modbus and Profinet ports found on: Overview of used ports on local host, with the same command. All ports were empty.
I have uploaded script rtde_control onto the polyscope with offset zero and deleted commands for other versions (I have 3.5).
Can someone help, please no matter what I try the same error occurs.
