Currently, I am trying to write a URCap that uses the RTDE. However, when I tested my URCap with the Robotiq URCap. It seems like we are trying to access the same RTDE port.
I tried changing my RTDE port around and I had no luck.
It looks like the OnRobot URCap has a similar compatibility issue with the Robotiq URCap:
Can someone explain if there is a way to coexist in the same environment?
I am bumping this thread. This still seems to be an issue between the CAPs. Is there any other caps having compatibility issues with Robotiq or OnRobot?
