Rotating base feature view on Move tab
The base feature view on the move tab shows the robot from the perspective of the +X axis (base). Is there a way to rotate that view? I thought I could adjust this from the Robot Mounting and Angle screen, but no matter what I adjust here it seems to have no impact. I know I can select the “view” feature on the Move tab, but that’s not too practical for multiple reasons. Just having the option to rotate where you are looking at the base feature from would be very helpful, even if it’s limited to just 90 degree increments.
Matt
You can create a new plane with your desired orientation in the installation tab and then use that plane as your reference in the move tab.
