How to open terminal or read out ip address within VMWare Machine as ursim lock terminal in guest mode.
I would like to ftp .urp file and test server-client application within ursim(client) and server,so that I could pre-program and test logic at home without real robot.
Inside the VM, e.g. the Starter Package, you can just run CTRL+ALT+T, which opens a terminal and try ifconfig to check your IP settings.
The admin password is easybot if needed at any point.
