Palletizing in subprograms causes null pointers
Steps to reproduce:
Create a program with a Palletizing node. Put it in a subprogram. Reload the program. Get Nullpointers.
Expected Behavior:
Normal operation
Actual Behavior:
Palletizing node throws null pointers
Workaround Suggestion:
Can’t use Palletizing in subprograms
Robot Serial Number:
Various
Affected Version(s):
Unclear
I’ve not personally had this problem, I’ve just seen it reported numerous times here on the forum with no response from UR. Please investigate this. @jbm
I use palletizing in sub programs. I have gotten that same error along with other issues doing so, but the workaround for me was to uncheck the “Save sub with this file” box in the sub prog, open sub, then open back up the main program. Hope this helps somebody out.
Hello, I had the same problem.
I solved it by creating installation variables in Installation → Variables.
By replacing these variables both in the main program and in the subprogram, the warning no longer appears.
Another report years later: NullPointerException Error
