Minimum Distance and Blend Radius
I have few poses/targets with circular blends as shown in the attached picture. There are two smaller arc moves and two large arc moves. There is no problem with the large arc moves. But with the smaller ones, the UR10e (PolyScope 5.22.0) is behaving differently. It retracts at the beginning of the smaller arc moves, almost like it is trying to skip the smaller arcs. The radius of larger arc is 17mm and the radius of the smaller arc is 2 mm. The distance between the smaller arc targets is 1.5 mm. Is there a minimum distance requirement between the targets when using movep/movec? Or is there a minimum blend radius requirement other than it should be smaller than the half the distance between two targets?
Is there a minimum radius of the arc that the robot can move successfully?
The script I am using is here:
set_tcp(p[-0.007, 0.088, 0.255, 0.0, 0.0, 0.0])
set_payload(5.0,[0.1, 0.0, 0.1])
movej([-0.78364,-1.39553,1.51756,0.5052,0.98766,2.72952],a=1.0,v=0.175)
movep([-0.78364,-1.39179,1.54278,0.47624,0.98766,2.72952],a=0.08,v=0.01,r=0)
movep([-0.77616,-1.39658,1.54813,0.47281,0.99372,2.73476],a=0.8,v=0.01,r=0.0002)
movec([-0.77502,-1.39855,1.55041,0.47207,0.99464,2.73555],[-0.77584,-1.40107,1.55343,0.47188,0.99398,2.73498],a=0.8,v=0.01,r=0.0002)
movec([-0.81577,-1.41137,1.56757,0.48395,0.96176,2.70653],[-0.81687,-1.37328,1.52219,0.49169,0.96088,2.70573],a=0.8,v=0.01,r=0.0002)
movec([-0.77844,-1.36333,1.50815,0.48041,0.99186,2.73316],[-0.77584,-1.40107,1.55343,0.47188,0.99398,2.73498],a=0.8,v=0.01,r=0.0002)
movec([-0.77813,-1.40266,1.55542,0.47235,0.99212,2.73338],[-0.78056,-1.40238,1.55521,0.47322,0.99015,2.73168],a=0.8,v=0.01,r=0.0002)
movep([-0.78805,-1.39756,1.54986,0.47665,0.98408,2.72641],a=0.08,v=0.01,r=0)
Does the same retract happen if you set r=0 on the moves around the small arcs, so there is no blending at all there? That would show whether it comes from the blend between the arcs or from the small movec itself. It would also help to know if anything shows up in the Log tab when it happens, and whether the start, via and end points of the small arcs really lie on the 2 mm circle you expect once converted to tool poses, since the controller builds the circle through those three points.
