M8 force/torque sensor part replacement questions
Can you replace an entire tool with force/torque sensor with the M8 male receptacle connector with the newer tool with force/torque sensor rather than using the adapter cable? If that is possible, on a UR5e, the part number is listed in the service and parts catalog as P/N: 124085. How is the part number nomenclature listed to differentiate between which gender M8 connector will be on that P/N?
