Lock orientations during freedrive
I would like to know if it’s possibile to limit the number the degrees of freedom of the robot while guiding the robot using the freedrive mode. I need to develop an URCaps where the user has to define 3 robot pose but I’d like to “lock” the orientation of the robot TCP and constraint the TCP’s movements to line on a defined plane.
I exploit the API uiapi.getUserInteraction().getUserDefinedRobotPosition(new RobotPositionCallback() {[...]} to get the robot pose, but I can’t find a way to limit the available movements during the freedrive.
Thank you in advance for your reply.
sc
there is no way to do so with the API. If you are using a e-Series robot or have an external FT Sensor, you can create this function by your own by calculating a force vector with the FT sensor and turn this vector into cartesian movement using the servoj command.
Thank you very much for your reply.
