Java versions used by PolyScope
Does this article help?
Compatibility chart and robot generations
URCaps are generally based on Java 6, since this is required for URCaps to execute on CB3, where only Java 6 is available.
PolyScope on e-Series is using Java 8. URSim are basically the same artifact as PolyScope on the real robot, so they use the same Java version.
The URCaps Starter Package uses OpenJDK 8 to support both URSim generations.
