Hi I am using the UR5e and recently I faced a problem C283A18 (lost too many joints safety packages)
I do not what is the source of problem?
I would appreciate your response
It is likely a hardware malfunction. Are you running the latest version of Polyscope?
I have seen that code before with a defective cable between controller and robot arm. So you could check that.
Can you check the error log for other errors appearing simultanuously but being “hidden” by that error?
Any update on this? Im having same issue but mine happened after joint replacement
Any updates on what solved this issue?
Hi everyone, were you guys able to solve this issue?
I had similar problems, replacing the cable from the controller to the robot arm helped. Reply if helped
to be honest, I tried that since we have two ur5e but didnt help.
