Error Message Wrist 2 : C26A1
I Have UR 5 CB3 Error, What Should I do?
The joint must either be replaced or repaired. :slight_smile:
You should contact your local distributor for further assistance.
I found this .pdf : (https://www.universal-robots.com/manuals/EN/PDF/Shared/ErrorCodes/ErrorCodes.pdf) and here’s what it recommends doing regarding your error code. :
"Could you please provide a list of authorized distributors or official representatives of Universal Robots in Indonesia?
Find din lokale forhandler af UR robotter | Universal Robots
unfortunately i could only find this page in danish, but it shows a map of distributors “fohandlere” and integrators of UR in Indonesia.
by looking further i see there are some marked on the map, but no way of knowing their name, i would recommend contacting UR for more information
You can also go to myUR and create a case in there. Then your case should be forwarded to the correct partner or service site. :slight_smile:
