Since we have an external Safety SPS I have to wire the EM-Stop Button from the UR5e to my Safety SPS.
Are there a documentation like wiring diagram from the EM-Stop and how to disconnect it from the UR5e?
TY ![]()
You can pass the emergency stop signal through to the Configurable Outputs. You can read more about it in the user manual. ![]()
Manual can be found here: UR Download | Support Site | Universal Robots
You’ll also have to change the Installation to set up the Configurable Outputs for Emergency Stop.
Unfortunately there is only the “Emergency Stop System” Signal. So when I pull out the EM-Stop Button the “Emergency Stop System” is still “LOW” till you reset the Robot.
This means I cannot reset the master safety system.
At the same time I cannot reset the Robot since the master safety is not reset.
