Eclipse is getting killed
I downloaded the newest starter vm image. But if I start Eclipse and Polyscope at the same time, they both start to run very slow, and after some minutes, Eclipse is getting killed.
Also when I start Eclipse this shows.
Udklip
Eclipse starts up, but also tells me to see previously reported errors, but where would they be located?
I tried to give it 1024MB of ram instead of 764MB, and that seems to have solved the problem so far.
Thanks for sharing your solution!
Generally this type of behavior is often tied to lack of RAM for the virtual machine.
