Access properties of a URCap program Node
Hi!
I’m trying to figure out how I can modify the properties of a URCap Program node(A) from another program node (B).
Basically, after adding A to B, I wish to set certain parameters of node B from A (egs datamodel keys).
Would appreciate if someone could point me in the right direction.
Thanks!
in the /doc directory of the SDK you can find the manual URCap Program Node Configuration. In the 5th Chapter URCap Program Node proprietary API a way is described to call as a URCap Parent node from another URCap-Child Node. See the following excerpt of the manual as a reference:
I’ll look into it. Thanks Stefan!
If this works for you, please remember to mark to mark the solution!
