What is the difference between get_actual_joint_positions () and get_target_joint_positions ()
how do i use get_target_joint_positions() ?
Hi @anon26936014 ,
Actual position means that it is the real joint position based on encoder’s reading.
Target position means that it is the “command position” based on controller’s sending.
Hi @sya ,
Thanks for the reply
Is it possible to move to the target position using get_target_joint_positions() ?
example please
Hi @anon26936014 ,
I think what you want is servoj which could move the robot to a setpoint(position) within certain time difference. Check the script manual or search the servoj in the forum and you will know it more.
@sya
I’ll try
Hi. @sya ,
servoj is different from what i thought
I only know the target point(TCP coordinates, not actual position). I want to get joint positions using this
is it possible?? If it’s not possible please teach me another way
Please help me… :sob:
Hi @anon26936014
You could check this thread as a reference.
Servoj need to fill in 6 joint position as a list so you could combine the get_inverse_kin() to convert your TCP position command to joint position command.
Hi @sya
Solved the problem with your comments
Thanks a lot :grin:
