Is there a function that allows you to check an input witch timer (like a watch function) ?
Not sure if you want to have an input active for an amount of time before proceeding, or timing out if an output is not active for a given amount of time.
Here’s both. ![]()
Note that the If command has the Check Expression Continuously enabled.
Will this work for you?
